SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.001303
SELECT cache_value
Params: 1
Run Time: 0.000301
LIMIT 1
Run Time: 0.000548
WHERE
AND frtRead.read_date IS NULL
AND (frtThread.expire_date > 1714135100 OR frtThread.expire_date = 0)
AND view_global = 1
AND active = 1
ORDER BY frtThread.order
Params: 0
Run Time: 0.000427
FROM `xf_thread`
WHERE (`xf_thread`.`thread_id` = '7868')
LIMIT 1
Run Time: 0.000624
WHERE
AND (FIND_IN_SET (18, node_ids) OR node_ids = '')
AND active = 1
Params: 0
Run Time: 0.000424
SELECT cache_value
AND content_type = ?
AND content_id = ?
Params: 1, node, 18
Run Time: 0.000190
FROM `xf_post`
WHERE (`xf_post`.`thread_id` = 7868) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 140) AND (`xf_post`.`position` < 160)
Run Time: 0.002179
FROM `xf_attachment`
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (172511))
Run Time: 0.000257
-- XFDB=noForceAllWrite
INSERT INTO xf_thread_view
(thread_id, total)
VALUES
(? , 1)
ON DUPLICATE KEY UPDATE
total = total + 1
Params: 7868
Run Time: 0.000090
SELECT `xf_user`.*
FROM `xf_user`
WHERE (`xf_user`.`user_id` IN (8888))
Run Time: 0.000256
FROM `xf_snog_forms_forms`
WHERE (`xf_snog_forms_forms`.`oldthread` > '0') AND (`xf_snog_forms_forms`.`oldthread` = 7868)
LIMIT 1
Run Time: 0.000487
SELECT view_date
FROM xf_session_activity
Params: 0, ܻ�
Run Time: 0.000084
UPDATE xf_session_activity
SET
ip = ?,
controller_name = ?,
controller_action = ?,
view_state = ?,
params = ?,
view_date = ?,
robot_key = ?
Params: ܻ�, XF\Pub\Controller\Thread, Index, valid, thread_id=7868&page=8, 1714135100, , 0, ܻ�
Run Time: 0.000094
SELECT `xf_user`.*
FROM `xf_user`
WHERE (`xf_user`.`user_id` = 3)
LIMIT 1
Run Time: 0.000250
bytes_sent | 13565 |
bytes_received | 740089 |
packets_sent | 172 |
packets_received | 1532 |
protocol_overhead_in | 6128 |
protocol_overhead_out | 688 |
bytes_received_rset_header_packet | 576 |
bytes_received_rset_row_packet | 215 |
bytes_received_prepare_response_packet | 99100 |
bytes_received_change_user_packet | 639516 |
packets_sent_command | 85 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 64 |
packets_received_rset_row | 30 |
packets_received_prepare_response | 1290 |
packets_received_change_user | 118 |
result_set_queries | 26 |
non_result_set_queries | 4 |
no_index_used | 2 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 26 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_once_executed | 27 |
rows_fetched_from_server_ps | 92 |
rows_buffered_from_client_ps | 92 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 25 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_binary_fetched_bit | 510 |
proto_binary_fetched_short | 465 |
proto_binary_fetched_int24 | 152 |
proto_binary_fetched_bigint | 983 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_json | 767 |
proto_binary_fetched_blob | 383 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 28 |
com_stmt_execute | 28 |
com_stmt_send_long_data | 0 |
com_stmt_close | 27 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_ps | 637188 |
